Archived
Schedules - specify writer to use for notification
Related products:FME Flow
  • Oct 4, 2017 12:00 AM UTC
  • 19 views
fmelizard
Forum|alt.badge.img+22
When using job service, its possible to specify the writer output to use for the notification on sucess/faliure.
This is not possible when scheduling a job.
jelle
Forum|alt.badge.img+23
  • Jan 18, 2018 11:40 AM UTC
I came across this today. My Workspace runs fine in FME Server, using the Notification mechanism at the time of publishing.
However, when using this Workspace as a Scheduled Task in FME Server, the Notification is ignored. It does not appear when monitoring the topic. The scheduler has the possibility to specify a Notification, but you cannot specify the Content (Writer). So, when you want to send an e-mail, assembled by the Workspace, it is not possible with a Schedule.
Current Workaround: put a text writer in the Workspace and prepare the e-mail completely. Make a second Workspace and use a WorkspaceRunner to run the main process. When it is completed, use a FeatureReader to read the text file with the e-mail information and connect it to an FMEServerNotifier
