Archived
Save number of records that went through each port when i save my script, so whe
Related products:Integrations
  • July 21, 2017
  • 87 views
***Note from Migration:***
Original Title was: Save number of records that went through each port when i save my script, so when i open my script at a different time I can review how the data flow went last time the script ran without having to run the script again.
jdh
Forum|alt.badge.img+41
  • July 24, 2017
lucky
  • July 31, 2017
It could be even better to load a generate log-file (Default is the last logfile) and Display the dataflow.
An alert should appear if the workbench is saved later than the logging has been done
rylanatsafe
Forum|alt.badge.img+14
Hi all, I've seen this idea – or those similar to it – pop up a few times here in the Knowledge Center.. please consider viewing the other related Ideas below and cast your vote!
Thank you for contributing to the FME Community!
