Released
SAP HANA Spatial
Related products:FME Form
  • Oct 29, 2015 12:00 AM UTC
  • 5 replies
  • 43 views
fmelizard
Forum|alt.badge.img+22
Make it even easier to load/retrieve/query/update SAP HANA spatial data
bruceharold
Forum|alt.badge.img+20
  • Jan 6, 2016 10:13 PM UTC
ArcGIS supports HANA as a geodatabase now, you should be able to go in that way.
steveatsafe
Forum|alt.badge.img+16
Hey @bruceharold, Would you be able to expand on the SAP HANA database versions that support Geodatabases? I am having troubles getting these details so if you have any links to documents would be great.
It seems that the first ArcGIS to support Geodatabase on SAP HANA will be ArcGIS Pro 2.1 and ArcGIS Enterprise 10.6. Can you confirm?
As a database, ArcGIS has been able to connect to a SAP HANA database for some time but I wasn't aware this was possible as a Geodatabase.
steveatsafe
I may have found what I was looking for... https://support.esri.com/en/technical-article/000012246
bruceharold
  • Dec 6, 2017 8:59 PM UTC
Hi Steve 10.6/2.1 is the first HANA GDB release. I was a bit premature saying 'GDB' at the time :-)
fmelizard
  • Jan 15, 2018 7:14 PM UTC
Hi @FMELizard, 2017.1 and higher supports SAP HANA Spatial.
