Archived
S3Connector needs to be further improved
Related products:Transformers
  • Mar 28, 2019 12:00 AM UTC
  • 30 views
The S3Connector would be useful if there could be a Writer that intigrates and uses the connection to an S3 bucket (i.e., treat it like a virtual drive. So anywhere you define a file path, an S3 bucket connection/path can be specified making S3 storage as transparent as possible.
Also, within the S3Connector parameters that there are only two options for "If file exists": Reject or Overwrite. It would also be very useful to add an Append option so that the same zip file can be used for scenarios where batches of workspace runs can be captured in a single zip file...
I'm hoping this gets into 2019 sooner than later.
Thanks for all you do...
Also, suggest adding a s3connector topic.
Forum|alt.badge.img+3
  • Aug 13, 2019 3:27 PM UTC
"Destination " needs an option to "Suffix Path Last Folder" in the "Download to Folder:". ie.
1. option = Yes: this is how the S3Connector currently works, it suffixes the last folder in the Path to the "Download as:" folder, then the contents
"Download Options - Path: folder1/sub1/sub2/sub3/"
"Destination - Download as: Folder"
"Destination - Suffix Path Last Folder: Yes"
"Destination - Download to Folder: folder2/sub4/sub5/sub6/"
-sub3 and it's contents will be downloaded to folder2/sub4/sub5/sub6/sub3/<contents>
-this is frustrating when you are trying to maintain the same structure under folder1 and folder2
2. option = No: in this case the Path Last Folder is left off and only the contents is downloaded
"Destination - Suffix Path Last Folder: No"
-sub3 contents will be downloaded to folder2/sub4/sub5/sub6/<contents>
For even more flexibility the Suffix Path Last Folder could be an integer to suffix the last N folders, with default 1, ie.
"Destination - Suffix Path Last Folders: 2"
-sub3 contents will be downloaded to folder2/sub4/sub5/sub6/sub2/sub3/<contents>
"Destination - Suffix Path Last Folders: 0"
