Archived
Run with Breakpoints without a Breakpoint Defined
Related products:FME Form
  • Nov 10, 2015 12:00 AM UTC
  • 5 replies
  • 76 views
Sometimes I just want to trace the follow of features through the Workspace when debugging. I have to define a Breakpoint somewhere after one of the Feature Types - and make an educated guess for the first one, or maybe I've disabled a Reader/Feature Type.
However it would be nice to be able to 'Run with Breakpoint' without one defined and popup a confirmation that says none found but would you like to use the first feature read to start the Breakpoint process. Clearly you couldn't 'Continue to next breakpoint' but could 'Step to next connection'. A very quick way of tracing a flow especially with multiple readers/feature types.
fmelizard
Forum|alt.badge.img+22
  • Nov 10, 2015 8:53 PM UTC
I like this idea.
taojunabc
Participant
  • Participant
  • Nov 12, 2015 3:23 AM UTC
I think add a "Run and break here" to the context menu with arrow line is better.
Because it is not always need to watch every step.
  • Nov 12, 2015 1:48 PM UTC
Isn't this what the existing 'Add Breakpoint' does ?
taojunabc
Participant
  • Participant
  • Nov 12, 2015 2:43 PM UTC
I mean not to add the breakpoint?Right click on any line directly,then select "Run and break here".
  • Nov 12, 2015 2:48 PM UTC
OK - I think both options have merit
