Archived
Run FME workspaces from within R
Related products:Transformers
  • October 16, 2017
  • 21 views
fmelizard
Forum|alt.badge.img+22
Currently, FME has the ability to interface with the R Project through the RCaller transformer. This means that R processing is initiated by a run from within FME.
It might be useful to run FME workspaces from within R.
One way would be to provide an R plugin that wraps FME workspaces. Similar to rGdal or rGdalUtils :
samatsafe
Forum|alt.badge.img+12
This is possible using existing R functionality. You can use the system or system2 functions from R package base to run an FME workspace or batch command file from the command line.
That said, an R package that lets R users run FME workspaces would still be nice.
