Open
Retry Handling in Split-Merge: Suppress Failed Output Messages
Related products:FME Flow
  • February 4, 2025
  • 34 views
itay
Forum|alt.badge.img+19
This functionality is great but does not make sense (the way it is now) inside a split merge block.
Let say you enable the retry in a split-merge block to try for 3 times before giving up, if it is successful the third time a feature will still come out of the failed port of the split-merge block and ruin you translation.
So either disable this functionality in the split-merge block (not preferred) or make is smarter and even if 2 of the 3 retries have failed don’t let any feature go out of the failed port of the split-merge block (preferred)
Let make the retry in a split-merge block usable (and great)
Itay
rylanatsafe
Forum|alt.badge.img+14
New→Open
