Archived
Resolve system parameter sent to Data Inspector
Related products:Integrations
  • Oct 31, 2016 12:00 AM UTC
  • 0 replies
  • 22 views
johanludvigsson
Participant
Forum|alt.badge.img+5
For instance: I use a system parameter to define a folder for a writer, in this case an Excel writer.
Problem: A writer set to $(FME_SHAREDRESOURCE_DATA)${USERNAME} est.xls will find or create the appropriate folder. But right click on the feature type and select Inspect and the Data Inspector gets confused because it will look for D:FME_support${USERNAME} est.xls.
Idea: Either let FME Desktop resolve the system parameter before sending the path to the Data Inspector or make the Data Inspector able to resolve the parameter on its own.
Result: Much more easy to do a quick Inspect when using system parameters.
