Open
Resolve Domains: Option to set _resolved field value as the original value when not found in domain
Related products:FME Form
  • Mar 7, 2024 5:35 PM UTC
  • 125 views
sammy
Forum|alt.badge.img+27
When resolving fields it would be useful in certain instances to have the option to NOT have the _resolved field set to <null> when the original value can’t be found in the domain. In these instances it would be useful to have the original value put in that field:
  1. For range domain fields: There is no code-description look up so all values are currently set to <null> in the _resolved field. All data from the original field is lost.
  2. For coded domain fields: When the coded value isn’t found in the domain the value is set to <null> in the _resolved field but there are instances where it would be good to have the option to not lose the original value (maybe also include a warning in this instance as stated in this other idea).
LizAtSafe
Forum|alt.badge.img+26
  • Jul 15, 2024 4:19 PM UTC
New→Open
