I have random points that need to form a line (straight line) with an attribute that identifies the different lines. When using the LineBuilder if the line is defined with more than 2 points, in some cases the node order is not following the logical order-> 0,1,2,3... example-> incorrect node order: 0,3,1,2) . As result of this lines are not OGC valid, containing self intersections.
An option to reset the node order will generate valid lines without overlaps.
Archived
Reset node order as option in lineBuilder
