Archived
Replace connection-vertex with Junction
Related products:FME Form
  • Apr 26, 2019 12:00 AM UTC
  • 80 views
lars_de_vries
Forum|alt.badge.img+10
Very often vertices on connection lines are placed carefully on the canvas. And than you find out that you have a connection line that needs to follow the same path. So you'll add Junction, but than the vertices in the connection line are removed and all your efforts go down the drain.
It would be a great solution if you can just right click the vertex and tell it to convert to a Junction on that exact position without bothering the other vertices in the connection line.
Forum|alt.badge.img+54
  • Apr 26, 2019 8:08 AM UTC
I'd also like an option to introduce a junction directly before a transformer/writer that would be connected to all the inputs of that transformer writer, in a single step
Forum|alt.badge.img+63
That can be done by right-clicking on the triangle at the input port.
  • Apr 26, 2019 12:20 PM UTC
Great, thanks
LizAtSafe
Forum|alt.badge.img+26
  • Feb 10, 2024 5:25 AM UTC
Updated idea statusGathering Interest→Archived
Idea merged into:
All the votes from this idea have been transferred.
