Archived
Removing parameters should invalidate transformers instead of resolving default
Related products:Integrations
  • Oct 5, 2017 12:00 AM UTC
  • 76 views
jdh
Forum|alt.badge.img+41
***Note from Migration:***
Original Title was: Removing parameters should invalidate transformers instead of resolving default value
Currently if you delete a user parameter that is referenced by a transformer, the transformer parameter is changed to be hardcoded to the default value of the user parameter.
It would be nice if the behaviour was instead like that of a missing attribute, where the transformer becomes invalid (red gear) and the missing attribute (user parameter) is highlighted.
rylanatsafe
Forum|alt.badge.img+14
I would like to have the option to specify the behaviour if it were to change... I voted for this, but my afterthought is I would get burned by habit.
Thank you for contributing @jdh!
LizAtSafe
Forum|alt.badge.img+26
  • Feb 12, 2024 2:33 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
