New
Remove the need of local database and web connections when deployment parameters are used from Flow
Related products:FME Form
  • March 5, 2026
  • 0 replies
  • 21 views
anryan
Forum|alt.badge.img+8
Hi there,
When using deployment parameters from various Flow environments, it would be great to actually used the stored information from those deployment parameters instead of having a local copy of that connection that is needed within the workspace.
The reason is, if I want to test and debug a workspace that happens to fail in a UAT environment. I would want to connect to Flow UAT environment, open that workspace and test it using the configuration that is stored in Flow UAT instead of the local version as this doesn’t represent to the environment’s configurations of connection, password, etc.
