Open
Remove Data Virtualization Logs from main job log area
Related products:FME Flow
  • September 15, 2025
  • 35 views
kieran.odonnell
Participant
Forum|alt.badge.img+5
Hi Safe team!
I think it would be handy to create some separation of job logs, between Data Virtualization and ‘standard’ FME jobs.
Depending on what you create with Data Virtualization, the volume of jobs which trigger could be substantial - and I think users will have very different needs for those two categories.
As an administrator, it will be very challenging to find particular ‘standard’ job(s) amongst all the DV job logs.
You may also want to configure the settings quite differently for the age of logs to keep.
It’s much more likely you’ll want to keep logs which trigger as a batch job weekly/monthly for a longer period of time (i.e 3 cycles so you have a comparison between jobs). Whereas with the DV job logs, they’re probably a bit more disposable, and not something you’re likely to be looking back on a few weeks/months ago for a single API request.
rylanatsafe
Forum|alt.badge.img+14
New→Open
