Released
Remove both duplicates with DuplicateFilter
Related products:Transformers
  • Dec 8, 2016 12:00 AM UTC
  • 5 replies
  • 194 views
Perhaps an option can be created in DuplicateFilter that flags both the duplicate instead of keeping the first one on and moving the other one under the "Duplicates" button.
I am working with a topological network and there is one point where a duplicate feature could cause false connections later down the road. In a case like this, I would want to remove both and examine them later rather than FME choosing one over the other.
Right now I had to use ListBuilder--> List Element Counter --> Tester to remove it. Not the best way for something that should be simple.
revesz
Forum|alt.badge.img+22
  • Dec 9, 2016 12:05 PM UTC
I do it with StatisticsCalculator Complete port -> TestFilter (love named outputs).
For such an option I suggest the Input is ordered by group as well to make the transformation less blocking.
erik_jan
Forum|alt.badge.img+26
  • Dec 9, 2016 4:48 PM UTC
Have you tried the Matcher transformer? I believe this can achieve what you need.
  • Jul 15, 2021 8:46 PM UTC
Thank you erik_jan, the Matcher transformer works perfectly for this purpose.
LizAtSafe
  • Feb 12, 2024 2:36 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • Jun 15, 2024 2:57 AM UTC
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/matcher.htm
