Released
Rejected Port option for custom transformers
Related products:FME Form
  • January 29, 2017
  • 78 views
todd_davis
Forum|alt.badge.img+23
The rejected port functionality showing the red circle and number and allow for features to be inspected on Desktop transformers has been of great benefit.
However there is currently no way to add this functionality to a Rejected port in a custom transformer. Instead, a port created for "rejected" features in a custom transformer requires a connection to be fully aware that something was rejected.
Any chance for the option for "Insert Transformer Rejected Output"?
jdh
Forum|alt.badge.img+41
  • January 30, 2017
You can add this functionality by naming the port <REJECTED>
Case matters as do the angular brackets.
todd_davis
  • February 10, 2017
Brilliant...thanks
jdh
  • February 15, 2017
This has been tagged as released, but there's no mention of it in the custom transformer documentation, and it's not intuitive since the case required does not match that of the standard FME transformers . ie <Rejected>
rylanatsafe
Forum|alt.badge.img+14
  • February 20, 2017
@jdh - Testing with Build 17249 macOS, FME Workbench seems to handle both <Rejected> and <REJECTED> Output Ports now.
