Archived
Regression Analysis Transformer
Related products:Transformers
  • April 20, 2016
  • 55 views
willydevera
Forum|alt.badge.img+10
Complementary to the StatisticsCalculator transformer, wouldn't it be great to have a separate FME transformer that emulates Excel's Regression function. In this case, esp. for spreadsheet lovers, we don't need to do an additional step of first writing our results into Excel then separately do Data --> Data Analysis --> Regression, in Excel.
Possible features for the proposed RegressionAnalysis transformer include Linear Regression and Multi-Variate Multiple Regression. Well if it's too much of an ask, we could perhaps start with Linear Regression functionality... :-)
However, if this functionality is already available in 2016.1 or in any planned future releases (BTW I'm still using 2014), please treat this post as a question rather than a suggested new idea. Otherwise, please let me know if this is possible at all.
Thanks,
Wilfredo de Vera, P.Eng.
Data Specialist
  • April 21, 2016
Just for info, I've done something similar with the PythonCaller and the SciPy library. It's not too difficult if you're comfortable writing some Python.
Can you share the workflow or at least the code used the the python called? I am comfortable with Python but a bit confused with using it in the FME environment
  • September 16, 2016
Sorry, I cannot share the code as it was for a client.
But it's nothing complicated if you have some Python basics
  • Download and install a full version of Python
  • Point FME to the full Python version (the one integrated with FME is a bit limited)
  • Download and install scipy
  • Import scipy inside PythonCaller
  • Extract values from your feature attributes using the fmeobjects api
  • Use values to do calculates
Hope this helps.
  • September 20, 2019
There are several R based custom transformers on the FME HUB that could be used as a template for R based Linear Regression and Multi-Variate Multiple Regression and also this article: RCaller: Ins and outs of using R in FME
