Archived
Read .tps files
Related products:FME Form
  • June 4, 2018
  • 21 views
xilef
Forum|alt.badge.img+5
Lots of municipalities are managing assets and property data through the use of flat files with extension .tps (Keystone software).
Currently, ArcCatalog is able to access the data using a paying ODBC connector from Softvelocity, but we're not able to to use this in FME.
Being able to read/access the data directly in FME would greatly improve current workflows.
xilef
  • June 12, 2018
After further testing, the ODBC connector from Softvelocity can work with FME's ODBC 3 Reader. Few tweaks to make it work:
- Specify manually the table name to reach: the 'table list' browser does not work
- No credentials required
