Open
Read only permission for schedules and connections in FME Server
Related products:FME Flow
  • October 11, 2018
  • 117 views
revesz
Forum|alt.badge.img+22
I'd like other users to see schedules and connections but not to change.
Now there is "None" or "Full Access" (edit/delete) options only (unlike Read, Write, Remove for Topics, Subscriptions, etc.) per schedule/connection. A "Visible" or similar option would be really helpful.
There are shared connections that I would promote to use but not to changed (same as in Desktop). Similarly schedules are OK to be visible for reference but shouldn't be editable to anyone.
jakethepainter
Forum|alt.badge.img+7
I agree with this. It would be helpful to be able to see when something is scheduled to run even if I shouldn't have access to modify it. And, sometimes you just want to see how a different schedule was set up so you can set up a new one not to conflict with it, or to borrow certain parameterization.
Definitely the same with server apps. I want to be able to view others' app configuration without being able to modify them.
aaron
Forum|alt.badge.img+12
  • July 5, 2023
Our department could definitely use a read-only view of our FME Server schedule. We have non-FME users in our department, including a supervisor and manager, who would benefit from being able to view the 40+ items in our schedule for reporting and knowing who to contact for troubleshooting issues that arise.
rylanatsafe
Forum|alt.badge.img+14
  • September 2, 2025
In FME Flow 2025.0, the permissions for Database and Web Connections have now been split into “Run” and “Write” instead of “Full Access”.
  • Run: Use the connection in a workspace.
  • Write: Full access to the connection.
No changes have been made to the Schedules’ permissions yet.
