Released
Published Parameters - indicate optional vs. required
Related products:FME Form
  • Oct 29, 2015 12:00 AM UTC
  • 64 views
fmelizard
Forum|alt.badge.img+22
In many cases, especially when integrating FME Server in custom applications it is neccessary to know if a given parameter is optional or not. For example to give the user visual feedback if a certain parameter may not be empty. This information exists in the workbench, but is not published through the REST Interface.
rylanatsafe
Forum|alt.badge.img+14
This has now been implemented in FME Server Build 18190 or Newer!
The web interface will now indicate required parameters that are not satisfied when the workspace is configured (and a run attempted) and the REST API now returns an "optional" : <true | false> parameter when queried – e.g. GET /repositories/< repository >/items/< item >/parameters.
rylanatsafe
FME Server 2018.0 has now been released! If you try to run a workspace without filling in any non-optional (i.e. required) parameters, these fields will be highlighted. See example image below.
