Archived
Publish Shapefile to ArcGIS Server or AGOL
Related products:Integrations
I am looking for a transformer, which will take a shapefile as input and then publish this shapefile on to ArcGIS Server or ArcGIS Online, this should be possible either in ArcGIS Desktop or ArcGIS Server, this is to remove the whole manual process involved in the publishing of such files.
rylanatsafe
Forum|alt.badge.img+14
You could wrap up a FeatureReader (Shapefile) and FeatureWriter (AGOL) in a Custom Transformer... but then it may not be dynamic as far as schema goes... Does this sound like it may help?
bruceharold
Forum|alt.badge.img+19
My tuppence: How about a generic file upload/download/update capability for all supported file item types, then ArcGIS Online can be used as a web file system.
fmelizard
Forum|alt.badge.img+22
Love this idea Bruce. That would make @saqibamin's issue trivial as well -- we'd just have the AGOLConnector be able to push a zip of a shape right up there...
fmelizard
adriano
  • August 18, 2017
There already is a Esri ArcGIS Portal Feature Service writer and a Esri ArcGIS Online (AGOL) Feature Service writer which will allow you to write to ArcGIS Server or ArcGIS Online. If you set up your featureReader (shapefile) name to be dynamic from an attribute in a workbench, this will give you the flexibility publish whatever shapefile you want to your Server.
