Currently you have to check the option to overwrite contents when importing a Project. If you forget to check the box, you might think that the import process was successful, but if an item already existed, it will be left as is. It is preferable from a UI perspective to get prompted if an imported Project contains items that already exist, listing out what those are, and give the option to overwrite any of those listed items. Do away with the checkbox and prompt instead!
