Released
Power BI Writer
Related products:Integrations
  • Dec 6, 2017 12:00 AM UTC
  • 9 replies
  • 290 views
fmelizard
Forum|alt.badge.img+22
Create a Power BI writer to enable use with FME Server to allow for automatic updates to Power BI dashboards without having to refresh/ping original (database) source.
Power BI Writer question: https://knowledge.safe.com/questions/59410/power-bi-writer.html
Fully Agree with you
fmelizard
  • May 23, 2018 5:40 PM UTC
Hello, for those that are interested in a Power BI Writer, can you elaborate on your use case? What functionality would you like to see? Is there anything that's an absolute must? Let us know in the comments.
fmelizard
  • May 23, 2018 5:58 PM UTC
See this related idea: TopoJSON
  • May 7, 2019 6:08 PM UTC
Power BI allows the developer to access data either by a direct connection to a database or by importing a dataset from a database. The import makes the operations in the Power BI report faster because the app doesn't have to go directly to the database, but the data is not fresh.
Are any plans to create an FME writer that could access and write to Power BI to emulate the import process? That way an FME script could be run on a regular basis to refresh the imported data.
jnotter
Forum|alt.badge.img+7
  • Nov 22, 2019 12:34 AM UTC
I would like to render a cartographic grid with thematic colors based on a column value and pie-wedge polygons as two layers that go into a PBI-rendered ESRI map.
kennyo
Forum|alt.badge.img+26
  • Jun 15, 2020 6:59 AM UTC
We are using Power BI more and more, and would love to see this writer, would make life so much easier
  • Mar 12, 2021 3:19 PM UTC
Not sure i see the point of a PBI writer.
We use PBI & FME for almost all our reporting, but we just update the PBI data sources with the regular FME writers (excel, sql, csv whatever) and then trigger the PBI Refresh on our report server.
We've made a custom transformer (basically a parameterised http caller) to do the refreshes.
scarter
Forum|alt.badge.img+10
  • Sep 30, 2021 11:59 AM UTC
Whilst being fully aware that PowerBI can consume .csv and .xlsx I have voted for this. I'm assuming the dedicated PowerBI writer would write out a .pbix file.
carmijo
Forum|alt.badge.img+12
  • Sep 23, 2022 2:42 AM UTC
Thanks for sharing info about this custom transformer!
