Released
PostGIS Reader should handle multiple geometry columns in a table
Related products:Integrations
  • Jun 24, 2016 12:00 AM UTC
  • 12 replies
  • 315 views
I store multiple geometry columns in a single table. I'd like to be able to use the PostGIS Reader to decide which geometry I'd like to pull out and transform.
ponceta
Forum|alt.badge.img+7
  • Aug 13, 2018 9:32 AM UTC
+1 Handling multiple geometries is a need.
I've encountered a bug when dealing with Postgis mutliple geometries table which requires to specify which geometry is taken into account, otherwise FME loses geometry :
https://github.com/qwat/qwat-data-model/issues/265
revesz
Forum|alt.badge.img+22
  • Aug 14, 2018 1:34 PM UTC
This may help:
https://knowledge.safe.com/articles/24702/handling-data-that-contains-multiple-geometry-colu.html
However yes, a more intuitive way would be greatly appreciated by many of us.
rbell
  • Apr 1, 2022 2:06 PM UTC
One of the advantages of PostGIS is that it can handle multiple geometry columns in the same table. For example and a polygon area of interest, then the gradual erosion of that AOI which regard to image collection, etc. Should not have to choose one or the other, in my opinion.
t_hohenstrater
I now too have this challenge whereby the table holds multiple geometries. Coming from Oracle Spatial and seeing how easy it works with FME I was surprised Safe has not implemented the same for PostGIS
winkel_tripel
I realise this idea relates to the PostGIS Reader, but it would also be good if PostGIS Writer could write to multiple geometry columns.
I tried the workaround at https://community.safe.com/s/article/template-write-multiple-geometry-types-to-an-exist, but writing the second geometry column is extremely slow, as bulk insert for this writer is switched off during translation (the following warning message is received):
POSTGIS Writer: Bulk Insert is set to Yes, but a conflicting Feature Operation has been detected. Feature type 'rc_srb.srb_01' has a Feature Operation of 'Update'. Bulk Insert is now being set to No, which can cause insert operations to be much slower
As a result, the timings for writing a dataset of 130,000 features is as follows:
  • 1st geometry column – 1 minute
  • 2nd geometry column – 42 minutes
LizAtSafe
Forum|alt.badge.img+26
  • Feb 10, 2024 4:33 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • Dec 27, 2024 7:53 PM UTC
Open→Gathering Interest
LizAtSafe
  • May 12, 2026 10:10 PM UTC
Gathering Interest→In Development
LizAtSafe
  • Sep 15, 2026 8:04 PM UTC
In Development→Released
andreaatsafe
Forum|alt.badge.img+17
Hi all,
In FME 2026.3, I’m pleased to let you know that the PostGIS Reader and Writer now handle multiple geometry natively.
For more details on how to work with multiple geometry, please check out this article here.
arthur_bazin
Forum|alt.badge.img+19
  • Sep 16, 2026 8:49 AM UTC
Hi ​@andreaatsafe, that’s a wonderfull news !
Will try it ASAP
Thanks
