If an Oracle Spatial table exists with appropriate metadata, when importing it as a Feature Type, could it populate the Format Parameters e.g. SRID, 2D/3D, Spatial Column, Tolerance, Extents etc. from the Metadata table?
Think it would need to be an option to apply these or a prompt "Do you want to apply settings from Metadata?". Maybe it is too difficult as you may use the schema but for a different format, but if the same format why not?
(Also may apply to other formats)
Archived
Populate Oracle Format Parameters on Feature Type Import
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
