Archived
PointCloudSimplifier - use less CPU
Related products:Transformers
  • January 17, 2019
  • 0 replies
  • 19 views
sigtill
Forum|alt.badge.img+25
With a new computer and 64GB RAM there is not much that can slow down my computer to a halt. Using SurfaceModeller, working with raster and liddart takes time, howeve it does not render my computer laggy/non-responsive when running. Even with large datasets.
But when using the PointCloudSimplifier this happens. It seems to be using 115% CPU. 60% memory still available, "no disk or network activity". Nothing else is running, computer is restarted and I have tried different las-files, smaller, larger etc. If it runs for 2 minutes or 2 hours the behaviour is the same.
Is it possible to tune this transformer to use a little less CPU so you can "work normally" withouth this lag?
