Archived
PointCloudExpressionEvaluator: Make Conditional work
Related products:Transformers
  • June 13, 2016
  • 39 views
ekkischeffler
Forum|alt.badge.img+7
Currently, the PointCloudExpressionEvaluator does not have a working option for a conditional value. The option is available but it does not work (error is "PointCloudExpressionEvaluator(PointCloudEvaluationFactory): Failed to parse the EXPRESSION_LIST clause..."). I've also logged this as C115855.
However, the function should not be removed but fixed. Otherwise we have to convert point clouds to points to do the conditional calculation and re-assemble the point cloud which adds to processing time.
  • October 20, 2017
@ekkischeffler
Hello! Is this fixed?
I am using this
but i get the following error
PointCloudExpressionEvaluator(PointCloudEvaluationFactory): Failed to parse the EXPRESSION_LIST clause. The provided value was '@EvaluateExpression(FDIV,STRING_ENCODED,FME_CONDITIONAL:DEFAULT_VALUE'0'BOOL_OP;AND;COMPOSITE_TEST;<Unused>;TEST;SS3Testset_bag_buildings'6'BOOL_OP;AND;COMPOSITE_TEST;<Unused>;TEST;SS3Testset_bgt_begroeidterreindeel'3'FME_NUM_CONDITIONS3___,PointCloudExpressionEvaluator)'. Please ensure that your syntax is correct
PointCloudExpressionEvaluator(PointCloudEvaluationFactory): A fatal error has occurred. Check the logfile above for details
Thanks in advance!
Regards,
Sravanthi
