Archived
PointCloudCoercer: Add an option not to convert color components to "fme_color"
Related products:Transformers
  • Sep 5, 2018 12:00 AM UTC
  • 0 replies
  • 27 views
***Note from Migration:***
Original Title was: PointCloudCoercer: Add an option not to convert color components to "fme_color" automatically
The PointCloudCoercer (Output Geometry: Individual Points) automatically converts color components - color_red, color_green, and color_blue to "fme_color", if you have set parameters to preserve the color components as attributes.
In some cases it might be convenient, but I found that it would just make worse the performance if you want to extract the color components individually. In my case, the workspace has to save every point including components into a MongoDB collection.
Firstly, I split "fme_color" generated by the PointCloudCoercer into three parts and restored original values, then wrote the points into DB. It took a long time.
Next, I renamed the color components with the PointCloudComponentRenamer beforehand not to generate undesired "fme_color". Result, writing speed with the second method was faster than the first method, 2+ times.
It would be better if the PointCloudCoercer would have an option to extract color components as is, without converting them to "fme_color" automatically.
