Archived
PATH Reader: Add where clause "like" functionality to only read certain files
Related products:FME Form
  • Mar 9, 2020 12:00 AM UTC
  • 46 views
setld_solutions
Forum|alt.badge.img+8
Currently, this reader forces the user to read all the files (w/ properties) into memory and THEN filter them in the workspace for size, date, etc.
I contest that I can get these properties much much faster via DOS DIR command written to .txt -- why can't the reader do this upfront?
Forum|alt.badge.img+54
  • Mar 9, 2020 9:59 AM UTC
These options already exist, you can use the path filter to restrict what files are returned
mark2atsafe
Forum|alt.badge.img+59
Yes, that filter uses a glob pattern, like a file system would. Interestingly, the linked article implies that the SQL "like" function is based on globs! Who knew? Not me.
