Archived
Parameterising the Inspector tranformer
Related products:FME Form
  • Oct 17, 2016 12:00 AM UTC
  • 82 views
When running a FME workbench in a production setting, it would be nice to have the Inspector Transformer set as a configurable parameter when running it from command prompt with the fme executable. This avoids editing the Workbench file and helps in quicker deployments.
fmelizard
Forum|alt.badge.img+22
  • Oct 17, 2016 5:58 PM UTC
This is intriguing, but I'm not sure what you're getting at. Do you mean that you'd like the inspector to NOT do anything when it is outside Workbench? I think this would make sense and might be what you're getting at. It would also ensure we'd not publish anything to FME Server that has the inspector enabled.
Well, I was thinking of something like:
fme.exe <abc.fmw>, Inspectors <On/Off>, Loggers <On/Off>
I would like to have Inspectors turned on when the workspace is being developed and tested. But when I put my workspace in a Production setting, I would prefer not to edit the workbench directly by disabling the inspector tranformer(s), rather to have them turned On/Off via the command line as stated above.
The Logger could also be an option that is controlled via a parameter to log info only when needed as long as the logger is connected/built into the workspace at desired logging points.
LizAtSafe
Forum|alt.badge.img+26
  • Feb 12, 2024 2:51 AM UTC
Updated idea statusGathering Interest→Archived
Idea merged into:
All the votes from this idea have been transferred.
