Archived
Parameter to disable Data Inspectors in the WorkspaceRunner
Related products:Transformers
  • Oct 18, 2016 12:00 AM UTC
  • 136 views
Earlier today (and I've done this before), I forgot to disable a Data Inspector in a workspace. I called the Workspace 600 times via WorkspaceRunners, which resulted in the Data Inspector opening 600 times!
My idea is to add a transformer parameter to the WorkspaceRunner that toggles the workspace setting, Enable/Disable Inspectors (I would disable by default).
Amit
  • Nov 2, 2018 8:38 AM UTC
I was about to post the same suggestion! Would be great! Another tweak to this one would be something to not let the DataInspector open as the active window. I'm running a smaller batch (20) of parallel processes with one inspector at the end so I can check if all went well, but now my computer is not really usable when I run this since these data inspectors keep on popping up as active windows. (But this one might fit better in the general FME options list)
LizAtSafe
Forum|alt.badge.img+26
  • Feb 12, 2024 2:51 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
