Archived
Parameter flow control
Related products:Transformers
  • Jan 8, 2018 12:00 AM UTC
  • 5 replies
  • 68 views
jdh
Forum|alt.badge.img+41
While we have flow control to route features along specific connections using the tester, it is inefficient to retest the value of parameter for each feature, especially when dealing with a large number of features.
It would be nice if there was some sort of FlowController which could route all incoming feature out of a specific port based on parameter value(s), which is only tested for once, and not a few million times redundantly.
fmelizard
Forum|alt.badge.img+22
  • Jan 8, 2018 9:37 PM UTC
Like an AttributeFilter but instead a "ParameterFilter"? Evaluated once, everything gets routed based on the value of the Parameter?
jdh
  • Jan 9, 2018 6:25 PM UTC
Exactly.
jdh
  • Jan 9, 2018 6:31 PM UTC
Ok, thinking about it a bit more, that's how I would use it, as the majority of the time I would use this, it's based on a Choice parameter.
But to make it even more powerful, it should behave like a TestFilter, specify the ports, and have one or more tests, evaluated in order, but only once.
fmelizard
  • Jan 10, 2018 9:30 PM UTC
Hmm, if the Tester/TestFilter could realize that there is nothing variant in the tests being applied, then perhaps it would just do what is wanted. So in that case this idea becomes "optimize test evaluation for invariant expressions" (or something a bit less obtuse than that)
jdh
  • Jan 10, 2018 9:42 PM UTC
That would do it, and mean one less transformer. Which means taking advantage of the improvement without having to go back and modify existing workspaces.
I'm sure you already know how I feel about optimization. :)
