Archived
Overview of used transformers in saved workflows
"I know I used this transformer before in one of my hundreds workflows, but which one?"
I like a tool where you can search for used transformers and which returns the names and locations of the workflows. Is there allready a solution or is it not a problem?
  • August 15, 2016
FME 2016 includes the "FME Workspace (FMW)" reader, it will create one feature for each object in each workspace (fmw file) it reads, including transformers. I think it should make it fairly easy to do just this.
Found it. Thank you!
blueinc
  • October 18, 2016
I've been looking for a way to do exactly this but I only have FME 2015.1. Ideally, it would also show me which FMWs have startup and shutdown scripts. Is there anything available for my current version?
  • October 19, 2016
You can always read the fmw with the Text File reader and parse from there.
blueinc
  • October 19, 2016
Will give it a go. Thanks!
LizAtSafe
Forum|alt.badge.img+25
Updated idea statusGathering Interest→Workaround Available (Closed)
