I'd like to be able to set transparency in Workbench Inspectors like in the Data Inspector application itself. This can be useful when viewing overlapping polygons using a consistent color each time. E.g. You can chosen a blue for one layer and a yellow for another, with transparency to create a green where they overlap.
It is possible to define fme_color and fme_fill_color FME Feature Attributes with transparency (RGBA) so the transparency support exists.
Hoping that is just a simple interface change!
Archived
Option to Set Transparency to Workbench Inspectors Vector Parameters
