Archived
Option to replace WorkspaceRunners with FMEServerJobSubmitters
Related products:Transformers
  • Sep 1, 2016 12:00 AM UTC
  • 0 replies
  • 26 views
courtney_m
Forum|alt.badge.img+23
I recently had a project, where I developed a runner workspace using multiple WorkspaceRunners. The client then decided to implement the process using FME Server. I had to delete all WorkspaceRunners, add FMEServerJobSubmitters, and reset the parameters for each Job Submitter (Note: Each child workspace had parameters that had to be set to a user parameter within the runner workspace, so the default values set within the children workspaces were not applicable)
If there was an option to convert a WorkspaceRunner (or group of WorkspaceRunners) to FMEServerJobSubmitters, with identical parameter values, that would be extremely helpful!
Thank you!
