ReleasedFME 2025.1
Option to have Test TestFilter Port Name Output as an Attribute
Related products:Transformers
romersl
siennaatsafe
+39
  • romersl
    romersl
  • char_firstname
  • lindak
  • siennaatsafe
    siennaatsafe
  • redgeographics
  • danilo_fme
    danilo_fme
  • asadamjad
  • warrendev
    warrendev
  • tcrossman
    tcrossman
  • vxn43
    vxn43
  • kennyo
    kennyo
  • canerakin
    canerakin
  • ranga_tolapi
    ranga_tolapi
  • milo89
    milo89
  • gbj1717
    gbj1717
  • nicohauri
    nicohauri
  • rhartley
  • bradr
    bradr
  • pangenib
  • mickleod
  • andre.utilit
  • pat_uow
    pat_uow
  • xabi
    xabi
  • alexvsn
  • sean_kurash
  • sacha
    sacha
  • davidlee
    davidlee
  • becchr
    becchr
  • anari
    anari
  • tschoppenhof
    tschoppenhof
  • geoal
    geoal
  • bozboswell
    bozboswell
  • reedwhit
    reedwhit
  • stevenjh
    stevenjh
  • tim.albert.vaa
    tim.albert.vaa
  • phoeffler
    phoeffler
  • veschwab
    veschwab
  • mapdog
  • michael.j
  • chris
  • cillingworth81
  • mavave
  • linda
  • p_c_20
    p_c_20
tim.albert.vaa
This would eliminate the need to add an Attribute Creator after every port if I want to use these test results for things further in the process like "Groupby" Functions etc.
erik_jan
Forum|alt.badge.img+19
  • January 12, 2017
You could use the AttributeCreator and use the option for conditional values.
fmelizard
  • January 13, 2017
This is an interesting idea for sure. I can see this being an interesting way of solving a long standing request as well. But @erik_jan is right that you can do a similar thing via Conditional setting. But still we'll consider this...
pat_uow
  • June 6, 2018
This would also be very useful after the change detector transformer instead of a separate attribute creator on each port. Attribute name to be set by the user, with values of unchanged, deleted and added ?
It'll be very handy option, please consider add this functionality to test filter
phoeffler
Forum|alt.badge.img+5
  • May 23, 2023
I agree that this would be helpful and is a sensible addition. As the TestFilter ports are not attributes, I do not see how to integrate the ports into the data flow with an AttributeCreator, even using Conditional Values? I checked attributes that were not exposed by default and couldn't find the ports there.
milo89
Forum|alt.badge.img+16
  • December 19, 2023
I completely understand that the AttributeCreator is able to generate similar results as I have a few workspaces with that exact functionality and it is often better if you need to generate multiple attributes based on a test.
That said, if they're processed differently based on the test/attribute I would generally be filtering straight after the AttributeCreator so this functionality could easily reduce the number of transformers required.
I see this as being similar to the '_predicate' attribute option from a SpatialFilter. You don't need to take the value but still available.
LizAtSafe
Forum|alt.badge.img+15
  • February 12, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
p_c_20
Forum|alt.badge.img+8
  • October 25, 2024
Did this idea ever go anywhere?
LizAtSafe
  • February 12, 2025
OpenGathering Interest
LizAtSafe
  • April 5, 2025
LizAtSafe
  • July 8, 2025
Gathering InterestReleased
