Archived
Option to configure the FME_TMP environment for Azure Kubernetes Clusters
Related products:FME Flow
  • Jun 14, 2022 6:17 PM UTC
  • 51 views
jsmitsman
Workbenches that produce a lot of disk io will perform poorly on Azure Kubernetes Clusters that are using Standard HDD OS disks.
Because of this; It would be really nice if you can configure the FME_TMP environment in the values.yaml file.
As solution for these clusters; you could then attach a new data disk with a better performance on your virtual machine scaleset, and set the FME_TMP environment to this disk.
This would be also really helpfull if you want more flexibility in the size of disk.
Otherwise
jsmitsman
  • Jun 14, 2022 6:35 PM UTC
Forget the last line: "Otherwise".
I forgot to remove this one. 😴
LizAtSafe
Forum|alt.badge.img+26
  • Apr 5, 2025 4:13 AM UTC
Open→Archived
