New
Optimize Connection Storage on FME Flow
Related products:FME FormFME Flow
geobroetchen
Forum|alt.badge.img+19
If a user changes the Connection Storage to FME Flow some challenges need to be solved.
Every time the user wants to add a new (Web) Connection which FME Flow doesn’t know, it can’t be added because the Service Definition need to be uploaded first.
For example, on a completely new FME Flow only three Web Services are available. If the user wants to add a Dropbox Connection it is not possible at all and the Web Service dropdown stays empty [1].
For now to upload the Service Definition the user has to change the Connection Storage back to Local Storage and choose one of the following ways
  • create a connection for this type and upload it to FME Flow
  • upload just the Service Definition to FME Flow via FME Form
After that the user needs to change the Connection storage back to FME Flow.
Idea:
Add the functionality to
  • upload the Service Definition if it doesn’t exist on FME Flow directly in the creation process for a new Connection, so that if a new Connection will be created it will automatically upload the Service Definition in the background
or
  • store the details in the background and upload these during the Publishing Wizard if it will be necessary for the process to run on FME Flow
[1]
geobroetchen
I forgot to say, that if I work on a newly installed FME Flow and change the Connection Storage to this FME Flow I can’t even create a FME Flow Web Connection because FME Flow doesn’t know the Service Definition for it [1].
[1]
denniswilhelm
Forum|alt.badge.img+21
I think it would be nice if your local service definitions would always be usable, even if you are using the FME Flow connection storage. Otherwise you are constantly going to switch between the two modes.
Forum|alt.badge.img+54
  • August 27, 2025
It does seem that it’s not quite a fully working solution
e.g. We have ArcSDE connections that are linked to a connection file stored on FME Flow, these are accessible via FME Flow connection storage but don’t actually work
j.botterill
Forum|alt.badge.img+69
I’ve been utilising Deployment Parameters recently to use the same named connection for both Test and Prod environments, simply switching the Flow Web connection.
The team saved them also with “% FME Flow” to distinguish, also due to escalated/different user/permissions.
  1. Same Deployment parameter name given in Prod and TEST
  1. Change the Value for each environment to point to corresponding SDE connection files…that are saved in Shared Resources > System folder.
  1. Be sure to utilise the Flow parameter in readers/writers/databasequerier $(FME_SHAREDRESOURCE_SYSTEM)
A deployment parameter with SDE files for Test and Prod… using Shared Resource System flow parameter
Careful in backup/restore that they get carried over! (they didn’t when I upgraded the directory from C default to a D drive expansion)
