Archived
OffsetCurveGenerator should preserve direction
Related products:Transformers
  • December 3, 2019
  • 19 views
becchr
Forum|alt.badge.img+35
The OffsetCurveGenerator comes in handy sometimes, but I think there's something confusing about it: it flips direction of the line for the 'Right' output.
Would be beter and more logical if both outputs would keep the same direction as the incoming line
jdh
Forum|alt.badge.img+41
  • December 3, 2019
I suspect it uses much of the same underlying code as the Bufferer, where you would expect that the direction of the right side would be in the opposite direction as the FME polygons follow the right hand rule for orientation by default.
