Archived
OBJ - Add parameter feature handler - to control quantity of flat surfaces used
Related products:Integrations
  • Nov 9, 2017 12:00 AM UTC
  • 0 replies
  • 29 views
***Note from Migration:***
Original Title was: OBJ - Add parameter feature handler - to control quantity of flat surfaces used to represent curve surfaces
We use FME to read DWG files and write OBJ files. When reading curved surfaces from the DWG mode, the OBJ writer decides how many flat facets will be used to represent that curved surface. We need more control over this to provide better fidelity for curved surfaces, cylinders and cones.
