Archived
No altering of geometry when using the Oracle Non-Spatial writer
Related products:Integrations
  • Jun 14, 2017 12:00 AM UTC
  • 52 views
bradr
Forum|alt.badge.img+9
When I update columns with the Oracle Non-Spatial writer on a Oracle table which contains a Geometry column that geometry is altert. The column is not listed in the 'User attributes' tab of the writer (Geometry never appears there) and on the 'Format Parameters'-tab there are no references to geometry. Despite of using the non-spatial writer it still writes or removes the geometry.
I am aware of the Oracle Spatial Writer option 'Update Spatial Colum(s)' to prevent so.
Advice: do not alter spatial column with the Oracle Non-Spatial writer
  • Jun 16, 2017 12:51 PM UTC
Would need to make that really clear to stop any regression by others actually using that feature.
Recently came across an issue using DatabaseUpdater where FME 2015 only updated attributes (what I wanted), but running same workspace in FME 2016 actually modified the geometry as well which my customer wasn't happy about.
erik_jan
Forum|alt.badge.img+26
  • Jun 16, 2017 1:45 PM UTC
Agree with @mark_1spatial: Changing this could hurt existing processes that rely on this behavior.
I would suggest adding an option to remove or not remove the geometry.
But the best option is to use the Oracle Spatial Writer as mentioned.
