Gathering Interest
New Reader/Writer: Bentley OpenRoads
Related products:Integrations
  • Feb 12, 2019 12:00 AM UTC
  • 8 replies
  • 223 views
runneals
Forum|alt.badge.img+32
Support readers/writers for Bentley's Open Roads, as many transportation agencies are using them.
ekkischeffler
Forum|alt.badge.img+7
What is the native format of OpenRoads?
runneals
  • Feb 18, 2019 11:30 PM UTC
I don't honestly know. I think it's a bunch of different ones including DGN, but I was thinking it's similar to projectwise.
  • Feb 19, 2020 6:55 PM UTC
its dgn with many layers under FileExplorer - very similar to Microstaion now than InRoads or GeoPack
jovitaatsafe
Forum|alt.badge.img+11
Hi @runneals​ and interested folks!
We're investigating the ability to read DGN files produced by Bentley OpenRoads Designer and we're looking for a sample dataset containing ORD attributes such as properties under 'Physical' that we can share with our third party library provider to see if we can get support added for reading these attributes.
If anyone has a simple DGN file containing ORD attributes that can be shared with our third party library provider, please feel free to reach out to me at jovita.chan AT safe.com. This will help our team investigate whether we can support reading Open Roads DGN files. Thanks!
it's a .dgn but Bentley 'hide' data in it. Pipes for example present as a single line when FME reads it, but openroads will present it as a 3D model of a pipe.
begugn
  • Sep 19, 2026 2:40 PM UTC
I have attached 2 files in a zip file:
ORD-Test.dgn. This contains:
  • Surface
  • Alignment
    • Active profile
    • Active surface
    • Projected profile
  • Corridor
ORD-Test+Utilities. This contains:
  • Same as ORD-Test
  • Drainage network (4 manholes and 3 connecting pipes)
  • Electrical cable.
Keep in mind that there is a 2D model and a 3D model. The 2D model is for plan production, and the 3D model contains the 3D models.
The files are made in OpenRoads 2025. If you need extra data in the file, just let me know.
andreaatsafe
Forum|alt.badge.img+17
​@begugn - thank you very much for the test datasets! This is very helpful for us when we eventually begin looking into developing a reader.
LizAtSafe
Forum|alt.badge.img+26
  • Oct 1, 2026 7:40 PM UTC
Open→Gathering Interest
