Open
New Reader: Exif Data
Related products:Integrations
  • Oct 10, 2018 12:00 AM UTC
  • 284 views
Rather than reading exif data from a specific image file format e.g. jpeg could a universal exif data reader be developed similar in functionality to the ExifTool by Phil Harvey. With the ExifTool you can point it at a directory, single file or a variety of file formats (supports approx. 186 formats) and it returns a table of image metadata. It works really well and I've created a FME custom transformer that makes a system call to the tool (https://hub.safe.com/transformers/exifreader). Other FME users might find this tool useful and it would be great as it's own reader.
https://www.sno.phy.queensu.ca/~phil/exiftool/
fmelizard
Forum|alt.badge.img+22
  • Oct 12, 2018 5:57 AM UTC
Great suggestion -- separate the EXIF reading from the actual raster format. We'll look at this... Thanks.
  • May 17, 2019 1:09 PM UTC
Just want to say that I've used this ExifReader transformer, and while it's a pain to get the ExifTool set up and running it's super useful. Thank you Jamess for making this. We don't need the actual image for our process, just the metadata. Using this tool sped up our processing time from ~20mins to ~20s. Having a proper reader which does the same thing would be awesome, as you wouldn't have to faff about getting the ExifTool set up.
  • Sep 15, 2020 12:16 PM UTC
We're looking at establishing a workflow for drone imagery. EXIF-information is important metadata which we need to pull out of the imagery to store together with other metadata related to a survey done with drones. Exifreader works, but I would rather want to have an option to analyse one picture at a time as a transformer.
max_h
Forum|alt.badge.img+39
  • Nov 27, 2026 7:49 AM UTC
Did anything happen in this regard?
I am reading lots of images from different locations, but I do only need the exif data+file location. Reading the raster and then removing geometry is quite time consuming
