Archived
New Format: Surface Weather and Marine Observation Markup Language (SWOB-ML)
Related products:FME Form
  • Jul 16, 2019 12:00 AM UTC
  • 45 views
Surface Weather and Marine Observation Markup Language (SWOB-ML) is an XML format based on the OGC Observations and Measurements standard.
This format is used by Environment Canada to publish detailed and highly-frequent weather station information from both EC and third-party sources across Canada.
Documentation for the format is available here:
https://dd.weather.gc.ca/observations/doc/
And sample data by date and station (CVOO has good info) is available here:
https://dd.weather.gc.ca/observations/swob-ml/
  • Jul 16, 2019 11:58 PM UTC
Uh, if it helps,
MWMMMMMMMMMMMMMMMMMMMMMWWWWMWMWWMMMMMMMM MWKo:oONWWWXkc,'.',:loONWXOoc,''';cxXWWW MWO, .oNWW0l,'.......',clc,'.....'.'l0WW WM0,..xMWKc..''.........''...........oNW WM0, .xMWKc.....................'..'.lNW WM0, .xMWNd'........................,kWM MM0, .xMMWXo'......................,xNWM MM0, .xMMMWNx:...................':kNWMM MM0, .xMMMWWW0l,................,dKWMMMM MM0, .dWMMMMMWNOc'............,l0WMMMMMM MMNkolOWMMMMMMMWXkc'......'.,o0NMMMMMMMM MMMMMWMMMMMMMMMMMWNkdc,..';dKWWMMMMMMMMM MMMMMMMMMMMMMMMMWMMWWN0olxXWWMMMMMMMMMMM MWMMMMMMMMMMMMMMMMMMMMMWWWWMWMWWMMMMMMMM XxcxNMMNkclk0dlox0NWMMMMKolodxKKoco0WMMM k'..lXXo. .ld' ...dWMMMXc.....o0, .dWMMM Wk,..;;..,kNO'... ,OWWWx......d0; .xMMMM MW0:....cKMMO' .'..:kKX:..'...dK; .xMMMM MMNo...'xWMWO' 'd: ..lo. 'o; .d0; .xMMMM MNo.....'kWMO' 'Ok.......l0: .dK; .xMWWM Xc..'do..'dNO' 'ONo.....'OK;..dK; .cdccd ;..,OWNd...xk' .xW0; .. ;KK:..l0; ....,c c..dWMMXl'lK0:..oWWkc:;,oXNd,.cKx,..lOXW
