Archived
Network Authentication parameters in Readers when reading from parameters or att
Related products:Transformers
  • Nov 4, 2021 4:46 PM UTC
  • 45 views
fgiron
Forum|alt.badge.img+25
***Note from Migration:***
Original Title was: Network Authentication parameters in Readers when reading from parameters or attributes
If you want to read from a URL stored in an attribute or a parameter in a FeatureReader you lose the possibility of setting the Network Authentication parameters, they only show up if the dataset value starts with http:// or similar
fgiron
  • Nov 4, 2021 4:51 PM UTC
As a workaround I'm concatenating the "https://" part to the attribute value and then striping it from the value itself, but that's not very elegant
fgiron
See this question too as another example where this caused trouble https://community.safe.com/s/question/0D54Q000080hSioSAE/how-to-set-the-reader-source-url-dynamicaly
