Archived
Named Value
Related products:FME Flow
  • February 4, 2021
  • 33 views
peter_s
Forum|alt.badge.img+4
Named Connections for databases and webservices is really useful.
It allows authors of FME Workspaces to separate sensitive information into "environment configuration" that in the case of publishing to FME Server also becomes manageble in terms of authorization.
It's often the case that the logic of an FME Workspace needs to be spread to a wider group than the sensitive information.
By physically separating these, there's less risk of the sensitive information being saved where it should not.
However, there are times when Named Connections cannot be used because they are to specialized towards specific applications.
This is where this concept would have its role.
Named Values should work in the same manner as Named Connections but be very generic on the kind of value that is managed.
Probably, the managed value should in fact only be a string value.
Access to Named Value would probably have to be implemented as some kind of macro substitution or function call.
Some keys to being useful as a concept:
  • It should be available to use anywhere in a Workspace
  • It should be available to use in all stages of the execution of a Workspace (before, parsetime, runtime, after...)
  • It should be documented clearly how not to use it, e.g. assign as an attribute to a FME Feature.
In my opinion related ideas:
https://community.safe.com/s/idea/0874Q000000TlQqQAK/detail
https://community.safe.com/s/idea/0874Q000000TkjuQAC/detail
https://community.safe.com/s/idea/0874Q000000TlGpQAK/detail
https://community.safe.com/s/idea/0874Q000000TlBAQA0/detail
https://community.safe.com/s/idea/0874Q000000Tkv6QAC/detail
https://community.safe.com/s/idea/0874Q000000Tl9DQAS/detail
peter_s
  • February 9, 2021
After having thought some more on this, an alternative approach could perhaps be to have a "parameter section" , much like private parameters, that is loaded from a managed resource. In desktop this would be similar to how named connections are stored/accessed, on FME Server it would be controlled by role access rights (also like named connections).
It should be possible to use as other parameters.
The main reason would in any case be to keep secrets apart from the .fmw-file so that the workspace can be distributed/stored in version control et.c.
