Released
MS Word Writer
Related products:FME Form
  • Jan 27, 2015 5:21 PM UTC
  • 15 replies
  • 90 views
fmelizard
Forum|alt.badge.img+22
Create simple MS Word documents. Features specify headings, text, pictures, tables which are strung together to make a document.
sigtill
Forum|alt.badge.img+25
Would be better with a Word READER and a TEXT PDF Writer with added maps inbetween - similar to Excel and references (or what it is called).
jeff_konnen
Participant
  • Participant
  • May 18, 2015 7:17 AM UTC
docx reader and writer would be appreciated
ekkischeffler
Forum|alt.badge.img+7
This should come with a Word document styler
maarten
Participant
Forum|alt.badge.img+3
  • Participant
  • Jun 20, 2016 12:20 PM UTC
Being able to write to a format (PDF/Word/...) in which you can combine text/tables and maps/images would be great.
ciarab
Forum|alt.badge.img+10
  • Aug 26, 2016 11:12 AM UTC
We currently have requirement to write to word, if we had the ability to style or use a template like excel writer that would be amazing
fmelizard
  • Aug 28, 2016 3:19 AM UTC
@ciarab : Jeff Konnen gave a talk on doing exactly this at the FME German UC in June. He produced amazing PDF output via Word using COM -- so Word itself did things under the control of FME. His slides can be found here and the last one has his contact info -- suggest you ping him and do let us know what comes of it.
srg
  • Aug 29, 2016 7:07 AM UTC
Being able to read and write to MS Word in which you can combine text/tables and maps/images will be an awesome addition to FME
  • Aug 29, 2016 12:26 PM UTC
ciarab
  • Aug 29, 2016 8:24 PM UTC
Thanks @daleatsafe , checking this out
ciarab
  • Aug 29, 2016 8:26 PM UTC
Just adding this link for others as there is an excellent example from Jan Bliki of the European Environment Agency if anyone is interested in writing to microsoft word
https://knowledge.safe.com/articles/1127/write-microsoft-word-docx-with-fme.html
bruceharold
Forum|alt.badge.img+19
  • Aug 29, 2016 8:53 PM UTC
Give Don the job of creating an OOXML writer and stand back :-)
  • Nov 28, 2016 12:15 PM UTC
It would be great to have such default functionality. We use the word writer for two years now and it helps a lot to communicate data quality issues to our providers. I published my MSWord-transformers on http://hub.safe.com.
fmelizard
  • Jan 10, 2018 1:13 PM UTC
The MSWordStyler and MSWordWriter transformers are in FME 2018 Betas. We are looking forward to feedback.
Is the Reader in the works as well?
fmelizard
  • Mar 12, 2018 6:55 PM UTC
Hi @dbaldacchino, not at this time. I'd suggest you post another Idea suggesting the MS Word Reader as a format.
