Open
Move log message filter settings from FME options to Workspace parameters
Related products:FME Form
  • Jul 5, 2024 7:23 AM UTC
  • 230 views
alexbiz
Forum|alt.badge.img+35
Did you know that log message filter settings are stored at the workspace level, not as part of the engine configuration?
Here's what the relevant section of an FMW file looks like:
Without debug:
LOG_FILENAME "$(FME_MF_DIR)none2none.log"
LOG_APPEND NO
LOG_FILTER_MASK -1
With debug enabled:
LOG_FILENAME "$(FME_MF_DIR)none2none2.log"
LOG_APPEND NO
FME_DEBUG MAPPING_FILE BADNEWS UNGROUPED UNCORRELATED DUMP_SCHEMA XSD_VERBOSE HTTP_DEBUG FTP_DEBUG FME_DEBUG STASH
LOG_FILTER_MASK -1
This setup makes sense, especially when publishing workspaces to FME Flow and needing consistent logging behavior.
However, in FME Workbench, this configuration is set under FME Options, which seems a bit out of place. It's not an engine or Workbench setting; it's specific to the workspace you're editing.
In FME 2024.1, there was a review of this area. Could we take it a step further and move this setting to Workspace Parameters? That way, it's clear and directly tied to the workspace itself.
rylanatsafe
Forum|alt.badge.img+14
Hi @abizien , thank you for your feedback!
I wanted to note that, in FME Flow, we now support enabling the Log Debug setting in Run Workspace, Schedules, Streams, and Flow Apps. (We will be adding support within Automations in a later release.)
We found that many customers unknowingly had published their FME workspaces to FME Flow with the debug enabled—which, in some cases, caused performance issues in production deployments.
I believe that if you do not re-save the FME workspace in 2024.1 or newer (or if you e.g. upgrade FME Flow and import the backup), then the log setting “embedded” in the FME workspace should still be honoured.
While we think the new setting in Flow (per workspace, per feature) will offer more flexibility, I will take your feedback back to the team to see if we can improve it further or find a balance between the old behaviour and new behaviour (in both Form and Flow).
LizAtSafe
Forum|alt.badge.img+26
  • Aug 15, 2024 4:57 PM UTC
New→Open
sammy
Forum|alt.badge.img+27
  • Jun 2, 2026 1:26 PM UTC
Can someone please tell me where to find the Log Message Filter options in workbenches newer than 2024? I am having a difficult time locating it as it is no longer under Tools(Utilities) → FME Options → Translation
