Archived
more information with error codes
Related products:Integrations
  • November 27, 2015
  • 28 views
mapper
Forum|alt.badge.img+7
I frequently translate data into Esri geodatabase format. I get the Geodatabase Error (-2147219115): The row contains a bad value regularly when creating a new workbench. this normally just has to do with field length or data type and is easy to fix once I identify the row with a "BAD" value. It would be great if that row was identified somewhere in the log.
  • January 10, 2018
It could report the Update Key field for writers or add a place to designate a key field in a reader so that could be what is reported with the error
For example:
An error occurred while attempting to insert a row into the table 'LAND_USE_AMANDA' using a cursor. The error number from ArcObjects is: '-2147215975'. The error message from ArcObjects is: {The number of points is less than required for feature} Feature: Add Key field here
