At the moment the order of input/output ports on a Custom Transformer is determined by the vertical ordering in the workspace. This seems awkward at best. I would like to propose a system similar to that of ordering Creator transformers or Connections. An alternative would be to use drag 'n drop in the Navigator to set the order, similar to the order of Readers and Writers.
I am aware that it is now possible for the user to change this order. That's fine, but I would still like to be able to provide a reasonable default. For example: I'd like my Rejected output port to be the bottom one.
Archived
Modify Custom Transformer Input/Output Order
